Re: Help! M does not run smooth
Posted by Allan In NE on June 13, 2014 at 09:18:39 from (199.47.66.59):
In Reply to: Help! M does not run smooth posted by Jim Stordahl on June 13, 2014 at 08:26:05:
80 lbs is awfully low compression. I'd run some top engine cleaner thru 'er and see if it helps.
Allan
