I put oil in each cylinder and rechecked compression. Compression increased from 80’s to about 90. Is that meaningful? What should compression be?
I reset spark gap to .40, seems to idle better….
When I had it idling, I tried the propane test around the intake manifold – every nook and cranny. I directed the raw gas around all surfaces, including carb gasket and all around the head gasket. There was no change in idle speed. If there was an increase, it was so subtle I could not hear it. Should it be obvious? Then I tried starting fluid, same procedure. When I woke up on the ground, it was still idling. Okay, the ether did not render me unconscious -- I’m kidding! Again, no discernable idle speed increase with starting fluid sprayed on those surfaces. I did not, however, try either of those combustibles on the head, should I do that too?
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
