Re: Farmall H Transmission Pilot Bearing
Posted by Eastsider on June 14, 2014 at 10:17:15 from (24.111.75.41):
In Reply to: Farmall H Transmission Pilot Bearing posted by mtjohnso on June 13, 2014 at 17:54:12:
NNP showed it exactly...it is a stepped down star washer...when you order your bearing, make sure you get the right one....there is a thinner one for the older H shafts and a wider one for the newer H shafts...I just repaired mine that had the incorrect wider bearing installed..not pretty!
