Posted by Fullers Farmalls on June 14, 2014 at 16:28:18 from (209.115.232.65):
In Reply to: First Farmall-H posted by JakeBrake on June 14, 2014 at 16:11:09:
They will crank slow if you have small battery cables. 6 volt systems need 00 gauge cables. Easiest source is welding lead cables. Clean and solder all battery cable ends. Then mount the ground, which should be the positive side of the battery, directly to one of the bolts that mounts the starter to the frame. Thatll get you somewhere close to turning over faster(given your starter is in good shape.)
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
