Re: 706 Fuel Gauge
Posted by Weldon K on June 14, 2014 at 19:17:45 from (98.16.31.129):
In Reply to: 706 Fuel Gauge posted by Cmore on June 14, 2014 at 08:01:02:
It is the sender unit inside the tank. You can take the sending unit out of the tank , examine it and you will see the thin metal spring that contacts the copper wire windings. Use a needle nose pliers or tweezers to bend the spring so the spring makes better contact on the winding wires. I did it to my 756 a few years ago and it worked correctly afterward.
