Re: coil
Posted by Charlieu on June 15, 2014 at 08:37:56 from (208.123.2.85):
In Reply to: coil posted by danmcdonald on June 15, 2014 at 05:04:17:
A 12 volt coil does not have a built in resistor, When a 12v coil is made it is made with many turns of very fine wire giving it a resistance of 3-4 ohms in the primary circuit. This can be checked with an ohm meter, connected to the neg (-) and (+) pos terminals of the coil. A 12v coil should read 3-4 ohms and a 6v coil will have about 1.5 ohm reading. This should be done with no wires connected to the coil if mounted on the tractor. keep-em-crankin Charlie U
