Re: ihc 4586 dash consel tell tale lites
Posted by jim_uny on June 15, 2014 at 14:19:56 from (24.213.206.167):
In Reply to: Re: ihc 4586 dash consel tell tale lites posted by Larry B. 1486 on June 13, 2014 at 18:25:18:
both starter relay and cab power relay under dash aok. neutral saftety sw bad and replaced. cable from starter relay to cranking motor(starter) solenoid
had continuity but no voltage but voltage when key on. supplied power probe 12v pos to solenoid and it energized so will replace cable.
