Re: 560d with 460d head
Posted by RPM1941 on June 16, 2014 at 06:44:13 from (173.18.253.242):
In Reply to: 560d with 460d head posted by doug vose on June 16, 2014 at 04:00:49:
No, same parts, there is a serial break, just smaller valves on early engines, same head gasket for all sizes by cubic inch, D236 in 460, D282 in 560, also D301 in combines. Simplest thing you can do is get .5 x 6 grade 8 bolts to replace the original head bolts from a quality supplier & remove the first 2 threads from each block hole, the blocks tend to distort around each bolt.
