Re: Follow up on H that wouldn't start
Posted by mkirsch on June 16, 2014 at 11:12:39 from (65.199.189.6):
In Reply to: Follow up on H that wouldn't start posted by pete 23 on June 15, 2014 at 10:15:33:
Why is it a "better system?"
The reason for the 12V bypass is because the voltage drops, sometimes dramatically, when you are cranking over the larger engines. A 6V coil will not fire on 4V, but it will fire on 10V.
Keeping the coil 6V and bypassing the resistor during starting was just a hack by IH to keep from having to put in a bigger battery and cables that could handle the job.
