Posted by Dave Allgire on June 16, 2014 at 13:28:36 from (173.12.233.69):
In Reply to: farmall B won't crank? posted by farmallstrong on June 16, 2014 at 12:09:16:
Just because you are reading 12.6 volts doesn't mean your battery is good. A new 12 volt, fully charged battery should read between 13-13.5 volts. With the starter in the vise and no load you do have enough voltage to turn the starter but, not enough when it is trying to turn the engine. The same goes for the starter switch, you don't have enough voltage (at 12.6) to get the job done. I'd recommend a new battery as it seems you have done everything else (cleaning connections). You might also look for any corrosion buildup (green or white looking stuff) in the ends of your battery cables too. That would indicate a high resistance not letting enough voltage through the cables. Just my thoughts.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
