Re: farmall B won't crank?
Posted by El Toro on June 17, 2014 at 05:06:25 from (96.244.7.206):
In Reply to: farmall B won't crank? posted by farmallstrong on June 16, 2014 at 12:09:16:
Get a hydrometer and check the specific gravity of each battery cell. Should see readings in the 1.280 range on a fully charged battery. Hal
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
