3414 international hydra. bucket cylinder
Posted by DSMITH15 on June 17, 2014 at 13:24:34 from (173.215.6.84):
I have a leak in the 2 1/2'' bucket cyl. The#378 740 R1 Key,
front head retaining, has the end bent so it won't catch in the
grove hole to advance the ring key around so I can get ahold of the tail to raise and turn the key on around and out. It is bent on about a 45 degree angle instead of a 90 degree. Has any one have any suggestions on how to get the key out. I am afraid to bend the end up as it might break off. Any help will be appreciated. Darold
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
