Re: Converting Super A-V to Super A
Posted by ericlb on June 18, 2014 at 05:02:34 from (67.142.161.23):
In Reply to: Converting Super A-V to Super A posted by ccaissie on June 18, 2014 at 02:56:37:
unless yours is a family tractor and has sentimental value it might be easier to work out a trade with somebody who has a A and would like the A-V
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
