So your A isn't running? Why can't you cultivate with the A until you get the new tire?
I would make do for now until you get the new tire for the A-V. Then I would sell the A-V and get a SA if you don't like the A-V. I know I would sure like to have an A-V.
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa
... [Read Article]
Latest Ad:
[More Ads]
