Re: Converting Super A-V to Super A
Posted by GENE BENDER on June 18, 2014 at 07:56:22 from (67.55.226.121):
In Reply to: Re: Converting Super A-V to Super A posted by john *.?-!.* cub owner on June 18, 2014 at 07:18:26:
Dont need to change finals why not just change the centers and rims or dont the centers fit the AV axles is the bolt pattern different.
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
