Re: basket case?
Posted by glennster on June 18, 2014 at 08:07:47 from (162.204.229.223):
In Reply to: basket case? posted by Nick Peregrine on June 17, 2014 at 20:38:12:
check your oil bath air cleaner and also the intake tube for debris or mud dauber nests. also check the choke linkage to be sure it is not slipping and leaving the choke on. also check your fuel flow to see if there is any debris in the tank, sediment bowl or carburetor. lastly check the distributor cap for moisture.
