Swap front castings (including front axle and steering, maybe even radiators) and rear wheels between the A and the Super AV. You'll then basically have an AV and a Super A, both useable. Do not know about the mid mount cultivator lift arms though. If you only swap front and rear wheels you end up with two mutts.
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa
... [Read Article]
Latest Ad:
[More Ads]
