Posted by Notjustair on June 18, 2014 at 08:36:34 from (174.229.70.111):
In Reply to: basket case? posted by Nick Peregrine on June 17, 2014 at 20:38:12:
You would be surprised how well they will run with the spark plug wires switched around. Verify that the wires are correct.
Are you sure that it isn't differential related - bogging due to a bad bearing in the rearend?
Sounds like you have electrical gremlins. I would use one of those books to rewire/check the wires from the ignition switch all the way to the spark plugs.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
