Re: Help! M does not run smooth
Posted by rustyfarmall on June 18, 2014 at 08:41:54 from (208.126.186.41):
In Reply to: Help! M does not run smooth posted by Jim Stordahl on June 18, 2014 at 08:09:08:
I feel that you are describing classic symptoms of a worn out distributor. My M behaved in much the same way. I found another distributor that seemed to be nice and tight, installed it, and the symptoms went away.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
