Re: How to check coild ohms
Posted by Bob on June 18, 2014 at 14:00:54 from (64.255.159.192):
In Reply to: How to check coild ohms posted by luke0927 on June 18, 2014 at 12:57:16:
With the primary wires disconnected, measure Ohms across the two primary terminals on the coil with and ACCURATE-at-low-Ohms Ohmmeter.
Before testing, touch the meter leads together and see that it "zeros".
A coil used for 6 Volts or on 12 Volts with a ballast resistor will be in the 1.5 to 2 Ohms range.
A true 12 Volt coil will be in the 3 to 4 Ohm range. (A HOT 12 Volt coil will be on the low side of that.)
