Posted by PaulW_NJ on June 20, 2014 at 06:45:57 from (108.35.229.108):
Finally trying to restart my 240U after rebuilding the engine, and discovered last night I had apparently put the distributor in 180 degrees out of synch with the valves. So it was firing on the #1 cylinder exhaust stroke rather than the compression (explaining the backfires but no start). OK, so I realize I need to point the rotor to #1 wire position on the distributor cap, while the #1 piston is TDC on compression. But how do I know the correct position of the distributor housing itself? While the distributor was out, I replaced the points with a Petronix electonics ignition, so I can"t watch for points opening.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
