Re: bad coil?
Posted by John T on June 21, 2014 at 08:34:50 from (216.249.72.121):
In Reply to: bad coil? posted by alderman on June 21, 2014 at 07:57:23:
It could be a bad coil, they have been known to breakdown at high temps. HOWEVER a condenser is much cheaper and they can also be more prone to failure when warm so you may try that first. Also check the points for excess carbon build and pitting and burning as that may be a cause.
Try easy cheaper things first like check connections, check switch (maybe try to hot wire it), try another condenser. A good old school mechanic may well have a high voltage coil tester
Does the coil have that classic burned electrical smell??? Any nasty black oil oozing out of coil??
John T
