The lack of a resistor will not cause the battery to discharge with the engine not running. It will prevent the engine from stopping when the switch is turned off.
Assuming you are using a 10SI Delco Remy alternator, check to make sure you have the wire from the battery stud on the alternator connected to #2 terminal and the wire from the ignition switch, through a resistor or diode, connected to #1 terminal. If #1 terminal on the alternator stays hot when the engine is not running it will drain the battery.
This post was edited by Owen Aaland at 11:27:46 06/21/14.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
