Re: farmall 350 5th gear
Posted by D Slater on June 21, 2014 at 12:50:51 from (184.14.183.67):
In Reply to: farmall 350 5th gear posted by jerry 4 on June 21, 2014 at 10:23:56:
Other than fifth when in neutral the gears are completely out of mesh. When shifted to a gear the shifter slides the gear around however wide the gear is. When shifting to fifth the gear just moves far enough to lock on splines of the transmission input shaft that is part of the T/A if equipped with one. So shifter doesn't move as far to shift to fifth.
Good used 4th and 5th slider gears are getting hard to find for the transmission. Don't thing you can get new ones. 300 also works and some other tractors like 460, 504 ETC. can be used if the lower 4th gear is also changed. That would change the ground speed in 4th though.
Its a bunch of work to remove stuff to look inside the transmission on a 350, but think that's what you will need to do if fixed. If equipped you can remove some wiring, unbolt hydraulic lines, fuel tank mounting and steering shaft at front and lift off all at one time.
