Posted by Rex Simpkins on June 22, 2014 at 13:24:59 from (69.251.237.110):
I have started tearing down my Super-C for my C153 project, but noticed the C123 currently in it has no serial number stamped on the flat boss where the numbers are always found. It is block number 366204R3 and has a dipstick behind the oil filter, but is fully across the back mounting surface unlike combine or swather motors. I took some photos and will attach showing no serial number-any ideas?????
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
