Soundsw like the original bolt was replaced with a carriage bolt. Those can be trouble but now that the bolt is broke you can remove the spring. Some have screwed the lug out with the broken bolt then it would be an easy fix. You can drill a hole for the easyout then heat and cool and then try the easy out. You will need to make more threads on a new bolt to have enough threads so you can adjust the tension properly adjusted the cult will lift easy. I liked mine until i sold it now i use the Cub I do have the lift levers for that cult.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
