Re: wheel weight bolts
Posted by DeltaRed on June 23, 2014 at 08:59:24 from (65.100.146.82):
In Reply to: wheel weight bolts posted by durrand liston on June 23, 2014 at 07:46:58:
The easiest way is to get some 3/4 'ready bolt'/all thread.cut to length.Use a tape measure to determine the right length.Measure wt thichness,wheel thickness,allow for fasteners. Do the math.
