Posted by jimb2 on June 23, 2014 at 18:39:39 from (99.240.243.222):
In Reply to: 574 Clutch Adjustment posted by 60 acre hillside on June 23, 2014 at 17:14:58:
Hi, if the clutch adjustment has been exhausted and the clutch is slipping then it is time to replace the clutch and pressure plate before the worn pads tear up the flywheel.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
