Re: Baling without a live PTO
Posted by MJ in the UK on June 24, 2014 at 08:39:01 from (86.165.45.62):
In Reply to: Re: Baling without a live PTO posted by hayfarmer on June 24, 2014 at 08:05:30:
Here in the UK there was no livedrive tractors until 1956. David Brown tractors had hydraulic lifts available from there introduction in 1939 so they offerd their version. It was a small wheel on a arm fitted just inside the RH rear wheel. This arm was controlled by a hydraulic ram and when you lifted the control lever up the ram pushed this small wheel down until the RH tractor wheel cleared the ground and stopped the tractor. Then when you lowerd the lift lever the small wheel came up and the tractor set off again. The tractor PTO shaft kept driving all the while you did this operation. MJ
