Re: rear tire oil leak
Posted by Dave H (MI) on June 24, 2014 at 10:23:10 from (50.108.87.18):
In Reply to: rear tire oil leak posted by pwyld on June 24, 2014 at 09:52:16:
Some things is in the shop manual and some things is in the operators manual and some things can only be found in the parts manual and some things you just have to take it apart and look at it because manuals back then assumed a lot on the part of the person doing the repairs and if it was "common knowledge" at the time you may not find it at all...like they don't tell you how to remove a screw. The trick is to find the right place to look.
