Posted by MKinON on June 24, 2014 at 10:59:08 from (174.91.107.130):
In Reply to: 140 farmall posted by Surphn on June 23, 2014 at 12:45:22:
On either side of the tractor, is a link running forward to the cultivator from the lift rockshaft. There you should see a coil spring along that link, with a set screw at either end of it, if memory serves me correct. It will likely be a square head, 1/2" wrench I think. The link is a rod at one end that slides in a tube at the other end, joined by the spring. You can adjust the link for length, with those set screws.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
