If one or both two holes forward of the seasonal disconnect or T shaped place leak its coming from the T/A clutch compartment. Seal or seals leaking if oil is getting in there. Normal for oil to be trapped above the plate even after all drain plugs are removed. Three seals can leak into the T/A clutch compartment. Forward wall of T/A clutch compartment has a IPTO drive gear shaft seal. Rear wall has a T/A carrier seal and a seal in the T/A carrier to input shaft or sun gear shaft. In t/a the input shaft turns in the carrier and in direct drive the shaft and carrier turns as one unit. So I guess it could leak more in t/a range if its the input shaft seal. All but the PTO drive shaft seal requires removal of the center housing and t/a unit. Other requires split at engine rear.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
