Re: 1456 slow starter
Posted by pete 23 on June 25, 2014 at 11:01:08 from (74.33.68.123):
In Reply to: 1456 slow starter posted by larryanderson on June 24, 2014 at 18:25:47:
Timing is extra critical on those four plunger Roosa Master pumps. Also fuel pressure of primary pump which is checked easily with a gauge. Those vane pumps blades wear badly and then you have little pressure at cranking speed and low pressure always. If it will idle down really slow when operating the lever on pump by hand when completely warmed up it is no at all likely to be the main pumping plungers or rotor. Forget about injection nozzles if it runs good. Like other poster said, valve recession is super critical and could be low from previous valve jobs. Problem with having pump tested is almost all shops will refuse to put on test stand before taking pump apart so you NEVER find out fuel delivery before any repairs are made. They don't want to contaminate their equipment.
