Re: rear tire oil leak
Posted by rustred on June 25, 2014 at 17:16:19 from (74.214.152.80):
In Reply to: rear tire oil leak posted by pwyld on June 24, 2014 at 09:52:16:
have never experienced that problem at all, as a person has to have some knowledge for simple stuff. never needed to find instructions to remove a wheel either, or check trans.oil level. the "shop" manuals will give you the specifications mechanics require, and are presuming you are qualified for the job. operators manuals get you familiar with the unit, and are a preventative maintenance kind of thing.
