Need HELP, Anyone had flywheel off sickle mower
Posted by 300guy on June 25, 2014 at 18:48:00 from (76.85.172.116):
Has anyone ever taken the flywheel off a 25, 27v, C-24-P or related sickle mowers? If anyone has, how have you done while it is on the mower? I need to replace the two noisy bearings in the main frame housing. But to get the shaft out the front where the 4 bolt cap is, the flywheel has to come off.
