Re: Farmall 460 coil ballast resistor
Posted by teddy52food on June 25, 2014 at 18:49:30 from (184.94.175.179):
In Reply to: Farmall 460 coil ballast resistor posted by Matt1983 on June 25, 2014 at 17:56:43:
What is the R post on the starter? The current may be grounding (short) there & causing the resistor to overheat. That wire should only be live from the starter when cranking, which gives the coil more power than through the resistor. In other words, it by-passes the resistor while cranking.
