Re: Farmall 460 coil ballast resistor
Posted by 300guy on June 25, 2014 at 18:52:04 from (76.85.172.116):
In Reply to: Farmall 460 coil ballast resistor posted by Matt1983 on June 25, 2014 at 17:56:43:
Starter uses about 3 volts from the battery voltage to operate it. Coils were designed to operate on 9 volts. So if the resister is used while the starter is operating, you are left with 6 volts and most likely no ignition spark. Therefore the resister bypass from the starter motor.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
