You got your answer. Just unhook that wire at R terminal of starter solenoid to check. Like they said, that terminal should be an open circuit until starter solenoid engages and then it supplies battery voltage to coil bypassing the resistor for starting. Your next problem is this. If it did not have a resistor before you most likely have a 12 volt coil so running through the resistor will reduce the current flow through coil and provide a weak spark. Look the coil over good to see if it say, 12 volts, or 12 volts with external resistor. Any body with an ohmmeter can check primary winding of coil and tell you what you have. If 2 ohms or less it requires a external resistor. If about 3.5 to 4 ohms it is a true 12 volt coil and you do not want a resistor.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
