It is normal for the resistor to get hot in the engine is not running, the switch is on, and the points are closed. If it is a new resistor or if any oil or debris happened to get on the resistor it will smoke. Like any other electrical heating element, as then resistor gets hot its resistance goes up and less current will flow through it. It becomes self regulating in that it may get red hot but should not burn out. But like a coil there is no guaranty that they will act as designed. Just don't leave the switch on without the engine running and youl will not have the problem.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
