Re: 140 hydrolic pump
Posted by ken house on June 26, 2014 at 18:34:23 from (173.242.241.201):
In Reply to: 140 hydrolic pump posted by Farmall4856 on June 26, 2014 at 15:20:26:
make sure that it if full of hydraulic fluid. then head tractor down hill. move levers back and forth quite a few times. this may get the air out.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
