Re: Compatibility of Implements for Offset Models
Posted by old on June 26, 2014 at 18:53:15 from (209.86.226.57):
In Reply to: Compatibility of Implements for Offset Models posted by F4RM@11 on June 26, 2014 at 18:39:50:
A lot of stuff form a cub will not work if run off the PTO due to the Cyb PTO turning back ward of most. Also the SA is a fair bit bigger so I do not think but can not be 100% sure that much else like the plow etc will work
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
