Re: 140 hydrolic pump
Posted by ken house on June 27, 2014 at 18:01:12 from (173.242.241.201):
In Reply to: 140 hydrolic pump posted by Farmall4856 on June 26, 2014 at 15:20:26:
head the tractor down a steeper grade, chock, scotch it good so it does not roll off. let it sit there a day or two ( this may bleed the lines a bit). try hydraulic again, move levers slow, full extent both ways, one lever at a time, stop at the end of lever travel and repeat. if this does not work, then i do not know. try another pump. it should not take over a minute to prime.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
