Posted by matt1983 on June 27, 2014 at 18:56:36 from (70.215.4.136):
In Reply to: Re: 460 oil pressure posted by pete 23 on June 27, 2014 at 18:35:59:
I pulled the oil pressure plug out but didn"t see anything in there(btw does the spring go back in a certain way? One end of the spring coil is tightly wound, the other end is not. I put the tight end into the cap and the loose end against the plunger), there"s a little scoring on the plunger but before the rebuild the pressure was fine. I"ll check it again. What is the plug behind the cover you are referring to? Also do the rocker arm post bolts go into the oil passages? I think I saw some oil coming up around the post when I was running the engine with the valve cover off.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
