Posted by rhtx55 on June 28, 2014 at 10:22:20 from (68.185.207.25):
In Reply to: 460 oil pressure posted by Matt1983 on June 27, 2014 at 14:59:27:
While you have the pan off plasti-gauge the rods & mains to check clearances to see if they are within specs. The only other place would be the cam bearings, if they weren't replaced this may be a contributor to low oil pressure at idle.
The next place would be the plate on the oil pump, perhaps too thick of a gasket causing excessive clearance between the housing & gears.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
