Re: main drive outer bearing
Posted by kub6040 on June 28, 2014 at 17:16:36 from (184.156.165.106):
In Reply to: main drive outer bearing posted by transtar61 on June 28, 2014 at 17:09:34:
May not hurt anything but you probably have a groove in the shaft where the seal rides that will cause a leak , might be able to shim it out a hair and get it to quit leaking.
