184 Lo-boy, clutch/ PTO idlers
Posted by pilot199 on June 29, 2014 at 16:28:35 from (184.46.40.186):
I picked up a '78 model 184 Lo-boy recently & I had posted last month about the clicking sound from the clutch area when I push the pedal in.
Someone wrote that there's a zerk fitting on the T.O. bearing but I can't find one. If it's there would it be easy to see or is this thing well hidden?
Also, the idler pulleys at the PTO; is the bearing on that interchangeable or do you just get an entire idler assembly?
Thanks,
Gary
