Re: Farmall M spindle thrust bearings
Posted by RPM1941 on June 30, 2014 at 06:54:14 from (173.18.253.242):
In Reply to: Farmall M spindle thrust bearings posted by IAtractorKid on June 29, 2014 at 07:01:20:
The picture shows its a later IH wfa off Super M & newer 400/450. This thrust bearing is the same clear up thru 656/7/8/9/10/12/14 06/66, early 50/ 5488, 815/915 combine, 1420/1666 same, it subs to a slightly smaller bearing but is correct.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
