Re: replace belly pump with woodsplitter pump
Posted by mkirsch on June 30, 2014 at 07:36:13 from (65.199.189.6):
In Reply to: replace belly pump with woodsplitter pump posted by Jason G Fabian on June 27, 2014 at 10:33:26:
Keep in mind that a woodsplitter pump is designed to be directly attached to a small engine that is turning ~3600RPM.
I don't know how fast the countershaft on an H or M turns, but it certainly isn't anywhere near 3600RPM. The pump will lose most of its capability.
