Re: questions for d slater/ leaking TA
Posted by D Slater on June 30, 2014 at 09:39:58 from (184.14.191.171):
In Reply to: questions for d slater/ leaking TA posted by jerry 4 on June 30, 2014 at 09:18:44:
Oil level is below the seals. Except there's a pocket where the t/a is located that traps oil maybe high enough to leak out the carrier seal to t/a clutch compartment when not running. Others won't have much oil to them unless running or tractor tilted out of level on hills.
Probably can see what side the oil comes from after the top plate on the center housing is removed. Unless its leaked bad enough to saturate everything.
Probably my last time looking at the computer today if any other questions someone will know the answer.
