Re: Hydraulic System on 460
Posted by ejr-Ia on June 30, 2014 at 09:55:00 from (204.11.182.29):
In Reply to: Hydraulic System on 460 posted by Hugh McKinney on June 29, 2014 at 19:15:48:
Their is a check plug on the side of the clutch housing to transmission which is on the side where the clutch pedal is which is the right side of the tractor.It probably has a square head on the plug that's your level of oil.Their is a 3 bolt plate by the gear shift that is where you put the oil in.
